My new beast
#77
I haven't had to make any changes to the Vantec to run LiPOs. I'm running a 6S 8000mAH LiPO in my KV-2. I wired it to run two in series for more capacity if needed. Your RDFR23 will run on any voltage between 5V-30V so a 6S LiPO is no problem. The only issue is that the Vantec does not have a LiPO low voltage cutoff. I use low voltage monitors on my batteries to ensure I don't drain my LiPOs too far. They emit a very loud squeal when the batteries hit the low voltage threshold I set. When they go off, it's time to stop playing and charge the batteries. Recently I did try to hook up the Open Panzer TCB with the Vantec controller with mixed results. Everything works great without the TCB. When the TCB was put between my new Frsky QX7 radio and the Vantec, I had one track that didn't want to go idle. It wanted to run all of the time. I recalibrated my radio, recalibrated the TCB, played with a bunch of the TCB settings, and tried to trim the movement out, but nothing worked. I'm thinking it might be an RF interference issue at this point. I have a bunch more experimenting to do to find the issue. There are some jumper changes I can make on the Vantec and do some testing directly connecting to the radio to find out where the issue is. I can't use my Spektrum radios with the TCB so I don't know if it's the radio or the TCB causing the track to move while the sticks are idle. I can also do some testing with my IFI Victor ESCs to eliminate the Vantec, but I need to get a signal booster cable for those to work with the TCB.
#78
Tankme, are you sure you meant to say those two 6s batteries are wired in series? Wiring two batteries in series doubles your voltage. To keep the voltage the same and still increase capacity you want to wire them in parallel.
#79
You are correct. That's what I get for responding to forums in between meetings at work... They are wired in parallel now. They were wired in series using the 12V SLAs to get the 24V I use...
#80
#81
Marcocaster
Try switching the leads from the Vantec to motors. If problem now moves to other side (left side only runs in reverse) may not be ESC. Test motors with just a battery as well - do they both run forward and backwards ok (reverse black and red wires on battery) when connected to battery? Check connections to receiver - nothing loose. Can you test a different radio/receiver combo? Do tracks on both sides run smoothly with no snags or jamming?
Could be EMI (electronic noise) interrupting or creating spurious radio signals. Is receiver located near motors or ESC? Perhaps move away from motors if so. Check antenna of receiver (wires pointed correctly if it has external wire antenna).
I personally like the Sabertooth's ESC for ease of set up though. It wouldn't hurt to have a backup ESC to the Vantec.
Bob
Bob
#82
Marcocaster
I wasn't able to find the exact part number of the motor you describe, but found something close. This is a Yaskawa UGTMEM-03 type motor. See attached specs above. Your motors are rated for between 6.8 and 8.7Amps MAX. So I would fuse them at 6-8 Amps (each motor). The voltages are in the 21-24 V range which explains why the original builder wired the batteries in series to use 2X 12V batteries to get 24Volts. I can email you the Yaskawa manual or you can down load it.
Bob
#83
Marcocaster
Bob
Bob
i did as you said. Swapped wires from esc to motors and the same problem it just switches sides now the left won’t go forward.
Did the test with the 9v both go forward and reverse as the should.
Noise? I have the esc and motors in the lower hull and the receiver up top on a bit of wood , thinking that may help with interference?
And finally the Fatuba radio. It is exactly the same. Right motor (or left if swapped ) will not go forward with either throttle left stick or turning with the right. I noticed originally the vantec was set up for just left stick drive and steer. Can I change it back to that. I am re reading the manual again.
Your thoughts? ESC problem ?
I am am going to eventually pick up
an ibu3 or sabertooth, it seems the ibu3 does both
thanks again!
#84
Do both motors run ok both forward and backwards hooking them direct to battery? It may be a ESC compatibility issue with the radio. You should be able to switch the Vantec from one stick drive to two stick control, not sure exactly how its done on the Vantec. With the Sabertooth its a simple DIP switch. Curious to see if that fixes it. Your speed controller is pretty old - it could be having trouble processing/interpreting the single stick inputs, but that seems like a stretch.
Ideally you want to isolate the receiver and antenna wires from motors - wood should help.
Not sure what the rating is on the IBU, but it sounds like Gary got it to work on the Hetzer. If you have the IBU2 or 3 - I would say try that before buying a Sabertooth. The Sabertooth is only a 2 motor controller, nothing else (ie not a multifunction controller). The IBU may be better /easier to integrate and get other features working (sound, gun traverse etc) as well as control the tracks.
#85
Just to be clear, I'm using a 6S LiPo battery to power a 2 by 32 sabertooth which also provides 5 volts to my receiver. The ibu2 pro and the Sabertooth are both plugged into the same channels on the receiver with Y cables. The ibu2 has its own power supply from a 2 cell lipo. I have so much room inside the hetzer that having separate batteries is not a problem. I also have a 12 volt, 3s lipo, that runs the entire fpv system. I could have used step downs to run everything from the 1 6s lipo but like I said, there's so much room in there it doesn't really make a difference. I run an LVA on all three batteries to make sure there are no ruined batteries.
#86
I would just switch the two wires on the side that's going in reverse. Swap the same motors' wires with each other.
But I'm an idiot when it comes to electronical things (and a LOT of other stuff!!!)
Mike
Mike
#87
Well fellas I think I killed the ESC it smells like burnt electrics
been reading over the instruction manual again and when I ran it the other day it was ok and then problems. So I think there should have been a fuse between the batteries and the ESC ? I have fuses on the motors and they are ok. But the burnt smell and the fact it only sort of works leads me to believe I made a $300 mistake so this guy is going on the back burner for a while until I figure out what the heck I’m doing and have some spare cash. Man it really sucks there are no more hobby shops (any shops for that matter) I could run down and ask advice. This internet is cool and all but one on one w real people makes it easier at least for me to learn. Oh well I’m not defeated. Just gonna stay away scratch my head and work on a 1/16 for a while.
cheers for the help fellas. Mark
#88
Hi Mark. Sorry to hear about the 'burnt smell' cause I've did it too.
You can order a Sabertooth 2X12 RC for $65. Sabertooth ESCs are GREAT and easy to wire to the motors. I use Sabertooths in all my large tanks.
And a while ago, when I was doing some wiring and was trying to figure out where to put the fuse breaker, I asked my brother (the ex-F15 electrician) and he said put the fuse between the hot battery lead and ESC.
Mike
Mike
#89
Marco
Sorry to hear about that. There could have been some defective components in the ESC which caused it to fry. Overtime (especially 20 years) components can go bad. Buying something used we have no idea what kind of life that ESC had - it coulda been sketchy with original owner as well.
The Sabertooth ESC have thermal and over current shut offs built into the design - so they don't get fried from heat or too much current. They also have the following advantages - have lipo low voltage shut off built in, use regenerative braking - as you slow or reverse the model it recharges batteries. Also they can power your receiver - no separate battery pack. It think Mike is correct the 2X 12 RC will get you back in business for $65.00.
A fuse is not absolutely necessary using the Sabertooth, but if it helps you sleep at night it is cheap additional insurance - its better to have redundant protection in place.
#90
Thanks guys. I am shopping for a sabertooth. I think the 2x12 is for 12v motors. The 2x32a looks like a good option. Would it be worth the extra over the 2x25 ? for the 24 volt motors. Going to save my lunch money for a week and get a sabertooth and a Lipo or 2 , new charger, Lipo bag and a new inline fuse! just in case 👍
cheers Mark
cheers Mark
#91
Good Morning Mark!
All my heavy tanks are using 2X25 Sabertooths with 2X5 ESCs for their traverse/elevation and they're happy. The 222 car weighs about 70 pounds, takes off and stops FAST, is 24v, and it has a 2X12 RC Sabertooth that's working great.
I think all the Sabertooths are the same and will handle low volts up to and well over 24v but are just made for different amperages. If I was running/battling a 'Battlebot' robot I'd get a big ESC but driving a tank around ain't a problem for'em.
Mike
Mike
#92
I got mine from dimension engineering and for some reason the 2x25 and the 2x32 are the same price, so I went for the 2x32. Better to have it and not need it than need it and not have it.
https://www.dimensionengineering.com...sabertooth2x32
#93
It doesn't hurt to have extra amp handling capability in the ESC - esp at same price. I'm using the 2X60 in my Stuart which is probably overkill - but it has been flawless performance wise. I figured this was about right if my motors can take a max of 80amps. I use a 2X5 RC for the turret rotation. I ordered mine direct from DE. Their support is very good for their products. The last number is approximately the steady state amps, in my case "60" not the voltage. As long as the ESC will take an input of 24V you should be fine. It will output the voltage and amps needed to run the motors.
One last thing get the "RC"version if you get the Sabertooths, it is simpler than the standard version, and slightly less in price. They all set up and operate the same however.
#94
Sabertooth 2x32 ordered . Also looking to get a breaker/fuse for the main power this time !
So fingers crossed I may have it up and running in a week. I tested the ibu2 I have in a taigen tiger and it seems good , a few quirks to iron out but it sound pretty good .
cheers mark
cheers mark
#95
The sabertooth arrived 2 days later wow those guys don’t mess around ! I also got some new cables from Aloft hobby also super fast ! Probably won’t get to it till Sunday. I was also wondering if one of these
Between the battery and speed controller would be sufficient or should I get something else?
And just for fun, if you guys were to do any painting to this what do you think would look best.
I am thinking just a light green and brown camo over the existing color , but very subtle?
Cheers Mark
Cheers Mark
#96
Marco
I think 50A is too much. Your motors run around 5A, with a Max of 8-10A, So I would fuse your track motors about 8-10A
As for the Sabertooth it has overcurrent protection built in. But if you want to put a breaker for it I would try 15-20A. Maybe 25A max. I can't tell on the Bussman if its resettable. You want a resettable type breaker.
Painting: a little brown and green would look great. Some of Schw PzJager Abt 654 early Jagdpanthers used on Normandy were just dunkelgelb yellow however. Later JP's in this unit had green, brown schemes.
#97
Marco
#98
I use those same blade fuses in the Hetzer, but mine are in individual holders. I'm using 30 amp fuses, but I have some pretty beefy Motors in there that draw a lot of current.
#99
Thanks Gary! I am going to use the fuse box so I don’t have to buy another part. I have almost read all the sabertooth manual and then I will give it a go. A question regarding the sabertooth the dip switches have what appears to be a clear cover over them? Is this a lift off cover ? Better update soon I hope
#100
Thanks fo the info guys ! Yea I agree w Jerry I don’t think the blanks would be a good idea here, I may just go for a flashing led ? So much to think about and plan. And honestly I have been into this hobby for about 5 yrs now and the electric aspect still makes me nervous. I am going to continue researching and gathering info and then decide how to proceed
Cheers Guys. Mark
Cheers Guys. Mark
