Reload this Page >
New Advanced Radio (AR) 26 channel receiver for spektrum futaba and jeti BEST GYRO!!
Old 05-11-2019, 07:45 AM
  #126
Digital Pilot
Digital Pilot's Avatar
I had a similar problem with MKS 777A+. The resolution is super hi on those servos. if you have small long servo wires it could cause the jitter.
Old 05-11-2019, 09:27 AM
  #127
Ceeray
Any european vendors?
Old 05-11-2019, 09:54 AM
  #128
Swisstyphoon
yes, Kingtech EU
I just ordered mine from Jean Marc
https://kingtechturbine.lu/index.php?k=70&lang=eng
Old 05-28-2019, 09:01 PM
  #129
rickgell
Hey guys, for anyone wondering about the Jeti RC switch.
Here is the video posted from the Australian distributor Phil.
https://www.facebook.com/JetProducts...7899345502832/
Simply plug the RC switch into the switch port of the Smoothflite or Smart Bus and away you go.
Old 05-30-2019, 10:17 AM
  #130
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Hi Brendan,
I talked to you on Friday May 17th at Joe Nall about the RC remote switch and setup for Jeti and the Smoothflite. Do you know when it will be listed on the website and be available for sale?
Gary
Old 06-06-2019, 06:53 AM
  #131
gilslo
Can we connect Jeti RSat 900 directly to Smoothflite ARXL ?
Old 06-08-2019, 10:29 AM
  #132
txshan130
My Feedback: (114)
txshan130's Avatar
Hi All -
Having some issues getting my Bobcat XL to feel right with the Smoothflite. Tried a bunch of different settings but would like a better place to start as it still feels pretty bad.
At the moment I have Autogain - on, Aileron, Elev and Rudder Proportional - On, and Aerobatic Mode - On. Using stock gains...
I tried Aerobatic Mode - Off and it felt horribly slow to respond. That's with zero expo at the moment.
Also, when I turn on the gyro, it appears to change the elev trim - inflight it starts a noticeable descent with the gyro on. Turn it off and trims go back to normal. That part was weird.
Can you all confirm what settings you are using with jets? Have you changed the factory gain settings?
Thanks in advance!
Old 06-08-2019, 10:50 AM
  #133
i3dm
My Feedback: (51)
i am using variable gain control with aerobatic mode on. and have the gain assigned to a knob
i found that i like it the best with my knob 3 clicks from the minimum position. rather low gain and flys awesome.
Old 06-09-2019, 01:34 PM
  #134
txshan130
My Feedback: (114)
txshan130's Avatar
Still having lots of issues. . Due to the aileron mechanics of the jet, the radio aileron travel must be set at 60%. If I set the radio aileron travel at 100%, I run out of endpoint travel in the Smooth flite. The mechanics of the servo and arms can not be changed at this point. I currently have low gain set at 5 and high gain at 9. Strangely, when I go from gyro off to low gain, the travel actually decreases. Going to full gain the travel then increases. I suspect that the radio 60% travel setting is making the gyro behave as though the jet is always flying right around the midpoint and adding in too much correction. Ughh... Getting frustrated. Thought this was supposed to be an easy setup.
Old 06-09-2019, 02:12 PM
  #135
rickgell
Scott, lets go to a plain vanilla setup and move forward from there. Turn off proportional mode, turn off Aerobatic mode. Deactivate just the aileron control {Ailerons Page-> SF Active} in the Smooth Flite and leave elevators and rudder active to start with. Fly that combination and see if the model feels locked in.
With the Smooth Flite the model may not need every control surface flying gyro to feel locked in. For example we fly one of our sports jets with just rudder on gyro. This gets rid of tail waggle, hold the nose up a little more during turns and makes the plane fly really locked.
Old 06-10-2019, 06:35 PM
  #136
rickgell
Default Smooth Flite Startup Offsset calibration.
There have been questions about some controls moving a little after startup. Also the model carrying slight trim change when the gyro is switched on. Here are some answers.
At start up (with the gyro switched to ON position) the Smooth Flite does a gyro calibration followed by and auto control offset calculation. To activate this feature make sure the model is switched on with the Gyro switch in the ON position (i.e. low or high gain position). You may see a bump followed by a second bump on some of the control surfaces. For best results it is important that you do not move TX sticks or physically move the model until the calibration has completed.
Old 06-11-2019, 05:45 AM
  #137
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Has the Jeti RC remote switch been released yet?
Thanks, Gary
Old 06-11-2019, 07:13 AM
  #138
causeitflies
causeitflies's Avatar
Thanks, Gary
You can use the Jeti R3/RSW receiver.
Old 06-11-2019, 08:38 AM
  #139
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
rick how long does calibration normally take? I have completed my install and awaiting a window to take jet out for first flights.
Old 06-22-2019, 02:41 AM
  #140
kelly vallee
Can we get telemetry function for Futaba with this?
Old 06-22-2019, 02:45 AM
  #141
i3dm
My Feedback: (51)
yes if course! im running this setup for some time. works great.
Old 06-22-2019, 02:50 AM
  #142
i3dm
My Feedback: (51)
There have been a lot of talks going on about Booma RC Smoothflite next version release.
i have been playing with this version for a bit before its public release and im so impressed.
RickGell and BrendanGell have taken the leading product in the market, to a whole new level!
The list of added features is simply overwhelming. i will add some teaser pictures for you guys though
notice that FrSky radios are now supported with an awesome custom widget for the Smoothflite.
Official release is coming within several days! 😍
Old 06-22-2019, 03:00 AM
  #143
kelly vallee
This is only a software update?
Old 06-22-2019, 03:01 AM
  #144
i3dm
My Feedback: (51)
yes.
new units will ship with this version starting very soon!
Old 06-22-2019, 03:21 AM
  #145
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
Dx20 fixes on the update?
And how do you do the update?
Old 06-22-2019, 03:23 AM
  #146
i3dm
My Feedback: (51)
cant comment on Spektrum as i use Futaba and FrSky only.
the update will be released to public soon and is performed on existing units using an update tool from AR.
Old 06-22-2019, 03:24 AM
  #147
i3dm
My Feedback: (51)
this is the update tool:
http://boomarc.com/en/update-cable-for-smooth-flite-and-smart-bus-rrs
Old 06-22-2019, 03:31 AM
  #148
rcflyguy_26
My Feedback: (8)
So we have to pay for a different cable? That probably should be included with the unit.
Old 06-22-2019, 02:32 PM
  #149
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
What are we updating exactly And is it necessary
Old 06-23-2019, 12:23 AM
  #150
i3dm
My Feedback: (51)
Please wait for the update official release which will include a list of the new features.
the update is not mandatory, you can choose not to do it
