Reload this Page >
Skymaster 1:7.5 F-4 Phantom
Old 10-25-2018, 12:44 AM
  #226
VS.T
VS.T's Avatar
nice jet!
Old 10-25-2018, 06:22 AM
  #227
redtail
My Feedback: (15)
redtail's Avatar
Luv Me Some F-4s. Chic
Old 10-26-2018, 03:12 AM
  #228
ozief16
My Feedback: (13)
One more pic: this one is a merging of a pic Warren took of my plane and one he took of a MiG a while ago. The end result is pretty cool. Thanks Warren!
Old 10-26-2018, 02:15 PM
  #229
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Very nice
Old 10-26-2018, 05:01 PM
  #230
Chris Nicastro
Chris Nicastro's Avatar
Good pic! looks convincing!
Old 10-28-2018, 08:34 AM
  #231
tp777fo
My Feedback: (28)
tp777fo's Avatar
After all the headaches jt is finally flying well. Got 6 flights on it this weekend. Still having some gear retraction problems, will change out Jettronics valve for a mechanical valve. Nose gear wont go up. Works perfectly on the ground. I zoom, slow, cycle and they come up the. Turn and burn. Landings a piece of cake.
Old 10-28-2018, 08:38 PM
  #232
ozief16
My Feedback: (13)
Tom,
great news! Post pics post paint
gkad you’re enjoying
Old 10-29-2018, 01:06 PM
  #233
tp777fo
My Feedback: (28)
tp777fo's Avatar
The entire squadron. T-33 hasnt flown yet.
Old 12-19-2018, 09:43 PM
  #234
aaronforth
aaronforth's Avatar
Originally Posted by Kevin_W
Jetcat P180RX, fuel pump, ECU on the right side.
It came in just under 33 lbs with fuel in the UAT only.
CG recommendations varied between 300-340mm, I was shooting for 325, it came in at 333mm with no additional weight.
Kevin_W
Where did you install your air tanks?
I was thinking above the pipe....is that a good idea you think?
Old 12-20-2018, 06:13 AM
  #235
tp777fo
My Feedback: (28)
tp777fo's Avatar
My air tanks are installed above the pipe. No problems with them.
Old 12-20-2018, 09:04 AM
  #236
Kevin_W
Originally Posted by aaronforth
Kevin_W
Yes, I installed all three air tanks above the pipe.
I also went with three separate air systems, one each for the gear, brakes, and doors. This worked out very well because on my third flight an air line in the door system melted under the turbine but since the gear was isolated on a different air system I was still able to get the gear down.
Make sure you put heat shielding over the air lines that run under the turbine.
Old 12-20-2018, 09:20 AM
  #237
aaronforth
aaronforth's Avatar
I was planning on 3 tanks but Gear/door, Brakes, chute.
as for the lines under the turbine I was considering installing the lower bypass. This should protect the lines. If I can only make it fit half decent 🤔
  #238
aaronforth
aaronforth's Avatar
thats good to know. Thanks !
Old 12-20-2018, 10:49 AM
  #239
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
You might have fixed it but I had the same problem with mine. I determined that the ball link on the struts was catching on the fount door. I added a block to the door like you would do on a king cat and it fixed it. The air load was pushing the door back. Dan
Old 12-20-2018, 02:28 PM
  #240
tp777fo
My Feedback: (28)
tp777fo's Avatar
Thanks Dan. Merry Christmas
Old 12-20-2018, 03:33 PM
  #241
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
The only problem I'm having is trying to keep the brakes from locking up. I had to order new tires. I'm using a UP brake valve and still have major tire wear even dropping the pressure . I just lubed the brakes with graphite that a buddy recommends and will see if that helps. Dan
Old 12-20-2018, 06:36 PM
  #242
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Look at you go lil fella! Even have your own cheering section. Hopefully I can finish mine in 2019. You need Aim7s from RSMP
Old 12-21-2018, 07:47 AM
  #243
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
Buck hope you have a great Christmas . What is RSMP? I do have all the bombs. Dan
Old 12-21-2018, 08:01 AM
  #244
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Ron Schwarzkopf model products. He makes Aim7 missiles for the belly of the jet, in addition to a centerline mounted gun pod and future works will be lau-10 rocket pods. Great stuff. Tell the girls Merry Christmas.
Old 12-21-2018, 08:04 AM
  #245
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
Thanks no buddy replied to my question of how to make the brakes not lock up. Any ideas out their. Dan
Old 12-21-2018, 08:17 AM
  #246
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
I used a BV smooth stop and had great success and never had to lube them.
Old 12-21-2018, 10:18 AM
  #247
Kevin_W
Dan,
I use a UP valve on mine and have not had any problems with the brakes.
When you say they are locking up, do you mean that they are locking up while braking (during roll out, after landing), or are they not releasing completely making it harder to taxi?
I have noticed that the brakes drag quite a bit even when released, so the wheels do not roll as easily as I would like. I think that issue is just a result of the design of the disk brakes. I was able to minimize it by adjusting the tension on the axle. As I recall, I loosened the axle so the wheel had some side play with the brakes released (.010-.015" I would guess).
BTW,
This is my Phantom with the RSMP Sparrow missiles attached:
Old 12-21-2018, 10:32 AM
  #248
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
When I apply the brakes they lock up easy. I can see the smoke coming off tires. As soon as I get the new tires I will see if the grafite helps. WOW you plane looks great. I might have to do that. Dan
Old 12-21-2018, 11:35 AM
  #249
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
As Yoda would say.... there is no try, do or do not that is all
lol
Old 03-22-2019, 06:53 AM
  #250
Ron S
Ron S's Avatar
I resurrected this thread because we are starting flying season again. Plus, it's a cool thread! A few pages back on this tread, Pat Fernandez threw out the idea of building Zuni rocket launchers for this model, and he didn't know, but I took him up on it. Here are a couple pics if anyone is interested. This is the LAU-10 rocket launcher, with missile noses that are removable. The launchers plug into the Skymaster F-4 TER rack. There may be other pylons they may plug into - not sure fully what is available from Skymaster regarding pylons...
I made a few of these pairs of launchers, but can make more if there is interest. You can PM me or email me at [email protected].
( Sorry for the gargantuan sized photos... )
LAU-10 parts available for Skymaster F-4 or similar scaled models.
Prototype Launchers, painted
A pair of model LAU-10s mounted on a Skymaster F-4 TER rack.
