Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 12-22-2019, 08:56 AM
  #526
airborn900
My Feedback: (25)
Originally Posted by ltc
Is JTM still in business making jets?
I think so.
TopRCModel Jets - CRX TURBINES
Old 12-22-2019, 09:20 AM
  #527
ltc
Originally Posted by Jim Cattanach
Just finished building my Odyssey. Weight came out at exactly 13 kilos. No added weight. Powered by Jetcat P130.
I am a bit concerned by the lack of give in the oleos. Even full of fuel, it takes a lot of downward pressure on the model to get the oleos to start to compress.
They are the Top RC oleos.
Anyone else had this problem & bad effects on landing?
Interesting that the TopRC Aspire seems to be sitting low on its Oleos in most pictures. I thought the 2 planes shared the same gear?
Old 12-22-2019, 06:32 PM
  #528
Jmav7279
I do believe the Odyssey and Aspire use the same gear. Mike at Gator Hobbies is the importer for the USA and has gear sets and replacement parts in stock.
Old 12-25-2019, 09:49 AM
  #529
bodywerks
bodywerks's Avatar
Originally Posted by AshC01
Hi mate,
I've just built mine, comes with everything required to complete the jet - minus RX, UAT & turbine.
all control horns, control rods, brackets, screws, bolts, ball links, tail pipe, dual fuel tanks, all included.
not many manufactures include UAT, as people have their own preference for use.
What about wire harnesses for all the servos?
Old 12-25-2019, 09:54 AM
  #530
bodywerks
bodywerks's Avatar
Originally Posted by horsefeetky
i have both jets odyssey is not built up yet but all items waiting on it. plan on 140n in it. taildragger rc has his for sale and it was his that caused me to buy one from him last year. super nice workmanship and watching one fly in the video is just how it is.. smooth light and honest.. it does need a uat and better linkages but once assembled it will last a long time.
as for the predator i have a k180 in it and it is more of a hard surface jet. a bit more weight than the odyssey but again a lot of plane for the money i bought the turbine ready version and very happy with all that was included and quality is great also. i did order the smoke tank from top rc direct and it got here in under 10 days and fits perfect.
guess it depends on what turbine you have in mind the odyssey will fly well from 120 up i would say predator is 140n and up power
also you can get the predator in turbine ready and save time and some money in the deal and your in the air faster
predator kevlar tank has uat built into it nice feature
Do you think the predator tank would fit in the Odyssey?
Old 12-25-2019, 10:03 AM
  #531
airborn900
My Feedback: (25)
I don’t think so, the odyssey has a tank that is shaped for the inlet ducting. The predator tank is a big rectangle shape. I don’t think there would be room.
Old 12-25-2019, 12:16 PM
  #532
ltc
Why not ask Carlos at CMJets to make a custom tank ?
Old 12-25-2019, 02:13 PM
  #533
jcpl
https://cmjets.com/toprc-model/223-odyssey.html
Old 12-25-2019, 03:51 PM
  #534
bodywerks
bodywerks's Avatar
because the more money I have to spend on this jet for better components, the closer I get to T-1 pricing with electric gear and xicoy controller. Similarly equipped, it's only about $500 more, and is lighter and more suited to the 160 I have planned.The only reason the T-1 is further down the list is the extra cost and build wait time.
Old 12-25-2019, 03:58 PM
  #535
ltc
Seems like an odd decision making process wren dealing with a jet ...
Old 12-25-2019, 04:08 PM
  #536
Jmav7279
The only things I upgraded were titanium rods and ends. The tanks are fine IMO but I did glue the vent fittings and the tank bungs.
Old 12-25-2019, 04:09 PM
  #537
airborn900
My Feedback: (25)
FWIW the T1 has semi symmetrical wing. I’m pretty sure the odyssey is fully symmetrical.
Old 12-25-2019, 04:27 PM
  #538
Jmav7279
Odyssey is full symmetrical
Old 12-25-2019, 05:17 PM
  #539
Dapreacherman48
Servos: 35kg, 40kg, or 46kg servos?
Im assuming coreless hv ht metal gear servos..,
what are you using (not asking brand but rather specs)
40mmx20mmx27(ish)mm
Old 12-25-2019, 05:19 PM
  #540
bodywerks
bodywerks's Avatar
How so? Not just tank construction, but included hardware, available gear options, available PNP options with a variety of different servos to choose from, e.t.c all seem like perfectly fine decision making process to me.
Oh, and speed envelop(I like speed).
I don't necessarily have an issue with the supplied fiberglass tanks, but they don't include a UAT like the predator tank and I have a spare predator tank is why I asked. And from what I'm seeing, all you get is the fiberglass carcass and it's up to you for fittings, which is more money to spend.
Does the Odyssey come with a wiring harness for the servos?
Old 12-25-2019, 06:09 PM
  #541
Dapreacherman48
I’m buying a UAT for mine.
i have not seen a wiring harness made for the odyssey. I’m running a variety of extensions and zip ties and wiring wraps.
Old 12-25-2019, 06:30 PM
  #542
Jmav7279
No wiring harness is included but I make my own. As far as speed...its as fast as you want to go within reason. I've got a SW-190 in mine which is overkill but I like vertical performance. The UAT I chose is a FCT 200ml clear tube which is a perfect fit. My servos (seven)are Savox 1230sg on 2 cell LIFE and work flawlessly and I believe they are around 500oz at $80 each. 30mm arms are needed and 75mm titanium rods if upgrading. The only mod I made is cutting a piece of 1/8 inch lite ply for the tanks to rest on...no structure on the belly. I'm using the bottom tank and top for fuel and get 8min of flying and land with 1/3 of the lower tank still full...hope this helps
Old 12-25-2019, 06:59 PM
  #543
bodywerks
bodywerks's Avatar
thanks for the info. I am currently flying a pilot 2.2 predator at 29.5lbs dry with a sw170b. I consider power and speed, er, decent. My concern is that this jet will be too similar to my predator in weight and flight envelop. Was hoping it would be lighter and that a 160 would be overpowered. Sounds like a 170 would suit my needs better, but there goes another $300...
Old 12-26-2019, 07:37 AM
  #544
Dapreacherman48
Mine came with plumbing...
Old 12-26-2019, 08:30 AM
  #545
Jmav7279
The tank hardware is questionable...i run(in all my jets) BVM heavy cluck, Bvm tank line, and Jet Tech bungs with M5 Festo compression fittings. Like I said earlier, Savox 1230sg is in all my 2m + planes with the same fuel fittings ,rx,batteries,UAT,and cortex pro gyro. It makes things easier for field repair because I need just a few parts.
Old 12-26-2019, 08:51 AM
  #546
Dapreacherman48
I agree... I don’t think I’ll use this plumbing. I think I’ll end up with the jct fittings and uat.
Old 12-26-2019, 09:23 AM
  #547
Dapreacherman48
Hi all, here’s an unwrapping video I did for the odyssey..
feel free to leave me feedback.
Spoiler
Old 12-26-2019, 09:29 AM
  #548
Dapreacherman48
so... I don’t know how to paste a YouTube link..
my apologies...
Old 12-26-2019, 11:25 AM
  #549
BarracudaHockey
BarracudaHockey's Avatar
my apologies...
https://youtu.be/K5fcf3sfMws
Old 12-26-2019, 12:02 PM
  #550
causeitflies
causeitflies's Avatar
Originally Posted by BarracudaHockey
After the latest RCU update all embedded videos are gone. Will this be corrected?
