Reload this Page >
New Composite ARF SU27
Old 08-30-2017, 12:53 PM
  #301
Auburn02
Auburn02's Avatar
Great pictures and very helpful, thanks! Wish I could find other similar equipment installation pics to get even more ideas.
I kind of figured I didn't want to create a situation where the cockpit needs to come out between every flight, thank you for confirming that.
I did consider adding the valves under the speed brake to keep them mid-ship, may take another look at that this evening. I would like to add the scale(ish) speed board cover plate that CARF provides, but if I use a bit of velcro to keep it in place maybe it could be easily removed to open/close the fuel valves.
Old 08-30-2017, 01:01 PM
  #302
skymaster68
I found this one on my phone, hope it helps... there you can see the 2 fuel valves and also the smoke valve in front of them... if not I can take a new picture during the weekend, let me know...
Old 08-30-2017, 01:13 PM
  #303
Auburn02
Auburn02's Avatar
Yep, I see, thanks again!
Old 08-30-2017, 02:33 PM
  #304
mave311
My Feedback: (13)
mave311's Avatar
Guys who are flying this model already, do you have your service items (switches, air fill, fuel fill, fuel shutoff valves) all accessible through the nosecone or do you raise the canopy and remove parts of the cockpit between flights? With no hatches around center ship, been trying to figure out how to lay those items out without creating unnecessarily long runs for everything but there may not be any way to avoid it. As of now I'm looking at having probably 12 or more feet of fuel line per turbine when you consider going from fill port in the nose to UAT near nose gear, then back up front to a shut off valve in the nose before going back to the pump and then turbines.
I have not yet started on the cockpit - once assembled can it be easily removed to access fuel shutoff valves and such if I were to install them around the nose gear mount instead of at the nose cone?
most guys are going through the air brake door....
Old 09-06-2017, 09:48 AM
  #305
Auburn02
Auburn02's Avatar
Anyone have suggested throws for the leading edge flaps/slats? The manual gives starting throws for all other surfaces except those. Thinking maybe 1/4" with takeoff flap, 1/2" with landing flap (measuring the opening at the wing seam, not the deflection of the leading edge) but that is just a wild guess.
Old 09-06-2017, 02:32 PM
  #306
mave311
My Feedback: (13)
mave311's Avatar
When I spoke to Andres, he stated that the aircraft is very stable, so full deflection on both slats/flaps on landing and half on take off....
Old 09-07-2017, 07:14 AM
  #307
Auburn02
Auburn02's Avatar
As luck would have it, I mocked up the wing against the fuse and deflected the slat until it stopped against the slot in the fuselage and the deflection was about exactly 1/2" at the root of the slat. So my 1/2" and 1/4" guesses might be pretty close after all. Thanks Mave.
Old 09-07-2017, 08:13 AM
  #308
DUCMOZ
Hi All
please be careful with statements like : Full Deflection or "as much as you can get". I lost a Skygate Hawk because what I could get in full Deflection of the flap was 3 times more than what another Hawk owner could get from his. The actual measurement as you are doing is the best way.
Behzad
Old 09-19-2017, 02:43 AM
  #309
RC Derek
RC Derek's Avatar
I use full slats and 1/4 flaps for take off and full slats and 3/4 flaps as well as air brake for landing.
Name:	31 (1 of 1).jpg
ID:	2232626   Click image for larger version
Old 09-23-2017, 12:17 PM
  #310
jetpilot
My Feedback: (48)
jetpilot's Avatar
What size pilots fit this?
Scott
Old 09-23-2017, 02:30 PM
  #311
skymaster68
I got a 1/6 pilot from taylored pilots... fits perfect...
Old 09-23-2017, 08:43 PM
  #312
RC Derek
RC Derek's Avatar
Scott
I use 10 inch pilots in mine.
Old 09-24-2017, 06:02 AM
  #313
DrScoles
My Feedback: (18)
DrScoles's Avatar
Derek, I see you have the fender on the nose wheel. Was it 3D printed by chance? Care to share the STL file??
Old 09-24-2017, 12:24 PM
  #314
RC Derek
RC Derek's Avatar
Yes it was printed but not by me.... took a bit of manual labour to make it work though. I will see if I can get the file.
Old 09-28-2017, 05:53 AM
  #315
Auburn02
Auburn02's Avatar
Are you guys gluing in the ventral fins or do they just stay with friction alone? I think permanently installing them would actually block the small hatch to the stab servo linkage, but wasn't sure if they would stay put if they were only pressed in so they could be easily removed for transport.
Old 09-28-2017, 06:30 AM
  #316
DrScoles
My Feedback: (18)
DrScoles's Avatar
there isn't place for a set screw? I haven't got that far yet.
Old 09-28-2017, 06:36 AM
  #317
Auburn02
Auburn02's Avatar
Nothing in the fuselage side and no mention of them in the manual - each fin just has two rods (fiberglass perhaps) that slide into carbon tubes in the bottom of the fuselage. They do feel pretty snug, but wouldn't want one to fall out across the field either. And they definitely interfere with storage/transport if you want to try to transport on a shelf with gear up.
Old 09-28-2017, 08:47 AM
  #318
Auburn02
Auburn02's Avatar
Originally Posted by Dave Wilshere
I've been working through Steve's build sorting the wing set up. The Slats took some time to get to where I was happy, two JR 6311's on each slat.
It peaks at 0.18 through the movement...hours of work!
I gotta ask, what sort of adjustments did you need to make to get it down to that low? I felt like my biggest issue would be the two servos fighting each other, but I'm getting a lot of drag from what I feel like is just the friction of the slat against the wing surface and not sure what can be done to lessen that. I wonder also if the servo linkages aren't exactly square and I'm getting some side load, but not sure how to smooth that out either since there is no room for ball links.
Old 09-28-2017, 09:13 AM
  #319
Dave Wilshere
Most of it was in the servo set up. But the slat did move smoothly with no grabbing. That's down to the sanding/cleaning to remove any rough spots. Then the four servos were matched in pairs and JR aluminium double arms used. This gets you nearest to a matched pair with no subtrim. I cut off the unused side. Then I clamped the two arms together and drilled the clevis holes in a pillar drill. I have a set of 0.1mm step drills and keep at least 10 of each between 1mm and 3mm as they are only good for a few jobs, before they are shot at that size.
The clevis pins were lightly greased to stop chattering which wears the holes and pins.
Then I set the movement with the inner servo only connected, then disconnected the inners and did the same on the outers and used the PB servo match to get it matched closed. Then I connected up the two servos with the H9 meter on the outer and used the Powerbox match to set the open position. The first wing too 4 hours, the second less that 2.
But the servos need to be mechanically matched as close as possible before you start!
Dave
Old 09-28-2017, 10:49 AM
  #320
Auburn02
Auburn02's Avatar
Thanks Dave! I did get the servos mechanically matched up, and basically to a point where the amp load on each servo at rest does not increase when the other servo is connected or disconnected (seems to reason that helps me ensure they aren't fighting each other anyway). Little grease on the pins seems like a fine idea though, and will check for any rough spots on the slats or wing themselves. I didn't mean to indicate they are grabbing, but more so the friction of the upper slat skin as it slides against/underneath the wing skin. But I'll feel for anything there that might cause extra load.
Old 09-28-2017, 03:29 PM
  #321
bluelevel
My Feedback: (39)
bluelevel's Avatar
The manual states that the 2 wing tubes are to be glued in the fuselage. The vertical fins have set screws to secure them on the rods.
Thomas
Old 09-28-2017, 04:31 PM
  #322
Auburn02
Auburn02's Avatar
Sorry, I was talking about the ventral fins that are underneath the fuse, not the vertical fins and rudders.
Old 09-29-2017, 02:50 PM
  #323
skymaster68
I did't glued them to the fuse, if you are transporting the plane you better take them out each time, as it will sit on them... if you want to make sure they wont fall use some velcro but it's not needed...
Also i had a partial Gear up landing,were the nose lg was the only one down, they saved me to scratch the fuselage, they are preatty strong and holded up really well with just some minor scratches, been flying with them afterwards and no issues whatsoever....
Old 10-01-2017, 12:48 AM
  #324
mave311
My Feedback: (13)
mave311's Avatar
gentleman just for info, it's been a while since i posted but i have to stress to keep checking the your slats before and after flights, another carf su-27 lost their slat in mid flight....hopefully the picture uploads...
in the picture, the left slat is missing completely..
Old 10-01-2017, 01:19 AM
  #325
Doug Cronkhite
My Feedback: (34)
It isn't gone, but apparently it folded under the wing completely.. Not sure how much the slats really add to an airplane this lightly loaded.
