Reload this Page >
Turbinator (V2) Thread
Old 05-16-2018, 02:43 PM
  #101
CARS II
My Feedback: (7)
CARS II's Avatar
Very nice!!
Old 05-19-2018, 05:45 PM
  #102
smoknrv4
smoknrv4's Avatar
Default Aluminium heat shield
Is that stuff about 0.25” thick?
Old 05-20-2018, 08:44 PM
  #103
GSR
My Feedback: (145)
No-it is 19/1000
Old 05-23-2018, 07:56 AM
  #104
smoknrv4
smoknrv4's Avatar
Originally Posted by GSR
No-it is 19/1000
thanks.
Old 09-18-2018, 04:25 PM
  #105
sam@ata
My Feedback: (16)
Anyone still sub'd to this thread? Im building my V2 i got 3 years ago and shooting to fly at a local jet event next month. Just looking for other hints and ideas going along. My layout is as such
P80 Propane start
Jr radio withe 12120 Power safe recv'r
Electric ProLink retracts
HS5645's on A and F, 5945 on each elev, 5955TG on rud
Using all the stock hardware and so far one small mod.
For the P80 i needed to use the narrow rails and instead of mounting the engine on the bottom, ie i would have had to cut the bottom cover, i installed asub rail above the stock and releived the stock rail so its actually a 1/4" higher up in the bay. I kept the stock 6 degree angle and will add washers under the aft mount bolts to increase as needed. The exhaust came to a littel above the sheet metal rear cover so i mod'ded the sheetmetal using the the thin flashing as mentioned here. Being an A&P sheetmetal mech in my prior mid life, i fashioned a new cover nearest the engine.
Hope to hear from others as this thread has been chirping for a while.
Old 09-19-2018, 02:00 AM
  #106
TPerk
Hi Sam@ata
I have had mine for a couple of years now. I used the hardware the came with the ART the only thing I needed to replace was the hinges. I found out after I had installed them that they are very bridle and they where breaking off, at least the ones that came with my ARF, I did find this before I flew it.I must say it is not ease to remove the old hinges. I used the 6 degree angle and on the engine. I used a K T 120 for flying off our grass field. I had to cut the bottom plate that goes over the engine, NP I hope this is of some help.
Old 09-19-2018, 04:03 AM
  #107
sam@ata
My Feedback: (16)
Stock sheet cover
Flashing metal used and will be two piece rear cover. The rear bottom cover plate fits without having to cut out for the engine.
Here are the pics of my sheetmetal mod i did for the rear. If i have to add angle to the engine then i may have to relieve it slightly but will see when the maiden happens.
Old 09-19-2018, 10:54 AM
  #108
TPerk
Wow you did a nice job, good for you.
Old 10-05-2018, 06:34 PM
  #109
sam@ata
My Feedback: (16)
Well, im setting up for my maiden tomorrow on my V2. JC P80 propane, pretty much stock build, Pro-Link electrics and AR12120 connected to a 11X On the road toward obtaining my waiver also. Pic to come later.
Old 10-05-2018, 08:28 PM
  #110
CARS II
My Feedback: (7)
CARS II's Avatar
Very Nice! mine is not an ARF , still in the bear bones, I'm planing to have it ready for the 2019 spring
Good luck on the maiden.
Pictures, pictures Plz
Old 10-05-2018, 10:46 PM
  #111
Jannica
Hello sam@ataI´m about to lay the last hands on a Turbinator with a JetCat P-80. I´m curious about how much weight you have added to the nose?
Jannica
Sweden
Old 10-08-2018, 03:00 PM
  #112
sam@ata
My Feedback: (16)
Curious if smoknrv4 has flown his. I installed the same thin flashing on the rear but during my test runs it waved and distorted due to heat. I had large gaps between the fuse and sheet between each fastener location. Once done running and it cooled, it went back to flat. I have an idea so I’ll post pics if ir works.
Old 10-12-2018, 04:40 PM
  #113
sam@ata
My Feedback: (16)
Its a done deal. Had the 2nd flight today and 2 more later. Here are my observations of the Boomerang Turbinator ARF V2
1. I had to add .25"under the the rear mounting bolt holes(7 degrees) more down thrust to the engine for a total of 13 degrees. This was just right and i still didnt have to cut out the bottom cover and inverted flight took min down elevator.
2. Throws as given are great for HIGH rates so no more than given is needed so i would suggest setting a DR at 70% with 30% expo on Ail and Ele for your start.
3.At least on mine, the thin flash sheet metal buckled under the heat and waved between the fasteners so i kept my first mod posted earlier and then changed out the remaining rear portion to the metal stock as supplied. No heat distortion and issue fixed.
4. On the fourth flight on this plane i was able to obtain my waiver sign off as its just a nice plane and that stable.
5. Added 13.5 oz under the battery compartment floor and that is with 2 4500ma LiFe rcvr packs, a 5000ma 2s ECU bat and a 3600 2s gear/brake bat up front. Total dry weight is 25lbs and maybe 2 oz.
6. New personal preference on flap servos, stick with analog and not digital as they become problematic as my two did. Even when setup with no binding or buzz in the up position, i managed to loose 2 in 24hrs, not during a flight but during final checks and assembly during the night before and morning of maiden. Replaced with 645mg servos and not issues
So there you have it, done deal from maiden to waiver. I plan to have lots of follow up flights in the next two days and plenty of touch n go's to become more familiar with flight characteristics.
Be glad to answer any questions you may have on your build or ARF
Old 10-20-2018, 06:21 AM
  #114
R/CBOONE72
Do you fly off pavement or grass? Im looking for my first turbine. I really want the k-85g2 engine and I could put it in the smaller turbinator 2 and have plenty of power. But I also want the bigger turbinator. I'm a 3d/sport flyer and don't know if the 85 will be enough at .6 factor with full fuel. Thanks
Old 10-20-2018, 08:19 AM
  #115
ltc
It will fly the plane, but grass takeoff roll will be long. How long is your club runway?
Old 10-20-2018, 08:23 AM
  #116
CARS II
My Feedback: (7)
CARS II's Avatar
Just to give you as to how much thrust is enough, my Boomerang XL is 42 lbs on TO ( 50 oz smoke fluid included ) been pushed by a 27 lbs thrust turbine, carrying a gallon of fuel, the TO run is like 300 feet long to be on the safe side, climb out feels heavy but it is moving, climbing with plenty of energy, after 3 to 5 minutesof flying it is moving fast ( as fast as Boomerang can move ) it didnt have for ever vertical but it climbs high enough for me, landing is at around 34 to 35 lbs, dry weightis 32 lbs.
I have a Turbinator that I build some time ago from a kit, I'm estimatingdry weigh will be 19 1/2, the K85 will be more than enough for it to have fun for a while.
Old 10-20-2018, 08:49 AM
  #117
CARS II
My Feedback: (7)
CARS II's Avatar
The Turbinator with a K85 flying off grass should be no problem, use 15° flaps, rotate at minimum flying speed then relax on the elevator a bit, let it accelerate to a safe altitude then have lots of fun with it
Old 10-20-2018, 08:53 AM
  #118
redtail
My Feedback: (15)
redtail's Avatar
A Great Build. Really enjoying the written conversation and pics. Chic
  #119
R/CBOONE72
I have about 600ft of mowed grass strip 90 feet wide with no obstructions except for a high kv power line about 1/4 mile put. The runway has some bumps so for the sake of the undercarriage I only have 300 smooth feet.
Old 10-20-2018, 09:09 AM
  #120
CARS II
My Feedback: (7)
CARS II's Avatar
More than enough I will say, if I had mine running I would've done a few TO off grass for a YT vid.
Old 10-20-2018, 02:12 PM
  #121
sam@ata
My Feedback: (16)
The K85, as mentioned above will be plenty off grass. As to my runway, FYI, i have 800' paved and the same grass right next to it. My dry weight came out to 25lbs and TO is with a gallon of fuel and if my A&P memory recalls, i think we used 6.6lbs per gallon for specific weight of JetA.
I believe the Turb2 with the 85 will be an overpowered setup and that could lead to issues in landing speeds being higher than needed and as your first jet, that will get you into trouble. If your getting the KT85 then i would suggest opt for the larger Turb V2 and if an 81" plane is to big, save some money and go with the Turb2 ARF and use a 60 size motor. I feel you will not be disappointed on either setup.
Old 10-20-2018, 03:50 PM
  #122
CARS II
My Feedback: (7)
CARS II's Avatar
True
Old 10-20-2018, 05:18 PM
  #123
R/CBOONE72
I could definitely enter the market alot cheaper with the turb. 2 and a swiwin 60 however my thinking is the 85 will transfer to a wider variety of Jets should I upgrade and I do not have the money for more than one turbine setup unless I sell my 100cc and 50cc birds.
Old 10-20-2018, 05:29 PM
  #124
R/CBOONE72
Anyone who has experience with both a boomerang Sprint/twin boom vs the turbinator. How do they compare in aerobatic ability with each other, I don't see many videos of the boomerang turb. And esp of the turb. 2. But the sprint/elan looks like it does pretty well for a high speed machine. Thanks
Old 10-20-2018, 06:57 PM
  #125
rcmigpilot
My Feedback: (26)
I can tell you exactly what expect, I have one with an original JC Rabbit that puts out 19lbs. Plane came is a just over 22 lbs. We have 700' of grass and with 15 degrees of flap and I seldom take 1/2 the runway to get up. Just got back from Louisiana Jets and it got off in about 150' from asphalt. I have Pro-Link trailing link struts from Dreamworks, they do a great job of absorbing the bumps.
