Turbinator (V2) Thread
#52
I have trouble seeing a 1%-2% throttle to elevator mix causing a problem
As in F3A planes, mechanical adjustments first and then small mixes to fine tune.
As my Turbinator (v1 prototype, very low downthrust angle) has a Cheetah (lots of throttle climb), I'll try the mix in the spring when flying season starts again
If it splats on a throttle up go around, I'll post back here
#54
The thrust angle solution exactly proportional, in sync with the cause of the problem, and time proven over hundreds of installations.
A throttle-elevator mix will be both out of sync with the thrust and vary with airspeed, creating two new problems while solving none.
#55
HI George, I am getting closer to having my Turbinator ready to fly, I did a balance test and I need 1lb 5oz of lead to get her balances at 7" on the CG, the batteries are a lipo and a life battery it looks like I will have 3lbs in the noise between the batteries and the lead to get her to balance out. I have the betties in the noise and the lead up there as well. It looks like you did not need so much noise weight. May I ask how you got the lead to fit in the holes you drilled out?
#56
My Feedback: (57)
#57
My Feedback: (47)
Hey George, building a turbinator V2 for a client. Glad to see your working on this thrust issue. I am going to go ahead and modify and add 15 degrees with a small JC Rabbit. I am glad I ran across this thread as I am literally installing the rails next. By the way, I also think the gyro will help from the nose climbing.
#60
I am just wondering how much weight was needed to balance the turbinator including your batteries? I will have 3lbs 1.5 oz of weight in the nose including the batteries in that weight of 3lbs 1,5 oz, that seem like a lot of weight, I guess it is what it is. I am balancing it at 7" back from l e.
#61
My Feedback: (26)
#62
Thank for the replay, I have a King Tech 120, the engines weight is all most 3Lbs I used lead shot and epoxy for most of the weight and I will use a stick on weight to finest the balance, so if in need to take out some weight after my first flight I can remove some weight. I added some great stuff foam to seal the epoxy and lead shot mix I had added to the nose.
#63
My Feedback: (26)
#64
This will be my first real jet and I am looking forward to flying her with the K T 120, the 120 puts out 27lbs of thrust so taking off a grass field should not be a problem, I think.
May I ask how much flap do you use for landing, does she slow down good for landing, or do you need to come in hot and fast. Any advice on land or any thing else you care to add would be great. Here is the lay out of the inside my Turbinator the large air tank takes up a lot of room in the front of the
plane.
plane.
#65
My Feedback: (26)
plane.
plane.
Mine is 23lbs (I think) with 19lbs of thrust and takes off in about 200' off grass, you will have no problem. I used the throws from the manual (half flaps on take off) and if you come in hot you're going around unless you have a thousand feet or more to slow down. I fly my base leg at 1/3 to 1/2 throttle (you'll probably use less as you have more power), come across the end of the runway 10' or so high, cut power to idle and have the plane stopped, w/o brakes, by the middle of our 700' grass runway. The Turbinator is tied with my baby boomerang for the easiest to fly jet I've ever flown.
#66
I am getting close to finishing my Turbinator and I need to set some down elevator mix with the flaps, may I ask how much down elevator are you guys using for half and full flap. I just need a good starting point and I will adjust the mix after I get a couple of flights on her. I balanced the plane 7" back on CG and I balanced it up side down, that seems to be better then right side up, I seem to be able to get a better balance point with the plane up side down.
#67
My Feedback: (26)
#68
Up date on my trubinator. I was able to get my first flight in a few days ago, this plane flies great. I only added 6o down thrust to the engine. I flew her at a bit more then 1/2 throttle and some full throttle passes down the field and I did not see the plane rise up at full throttle, so I guess Larry from boomerabg rc jets was right no need for a 15o down thrush, for what ever it is worth. I have a 120 kingtech in her, nice engine.
#69
What is your total downthrust (including your 6 degree added)?
Can you make a measurement or post a picture?
#73
I set up my jet on a stand and checked to make the wings were level, then rechecked engine mount for down thrust, just to make sure I was right about how much the down thrust is on my jet and yes I have it set at 6o total down thrust. I also check the built in down thrust and it comes with 2o down thrust built in to the engine mount . I am not trying to say any one is wrong about using 15o down thrust, but my jet files great with 6o total down thrust and she did not seem to noise up at full throttle. I set it up with the 6o down thrust after talking with Larry from Boomerang Jets, he has less the 6o down thrust in the one he uses for flight demo at the jet rallies he goes to.
#74
Hi All, Has any one been flying there Turbinator ? I am sure all of the guys that have posted on here must have had some flight on there jet, how are you guys making out? I got my Turbine waver a couple of weeks ago, Andy Kane from Carf Models and Dennis Blades was kind enough to sing off on my turbine Waver at the Hurlock Md Jet Event, Yahoo. LOL
I have had 5 flights in so far and I am having a bit of a hard time remembering to keep the power up on landing, but I am getting there. I hope to hear back from all of you. Here is a link to some photos from the Hurlock Md jet event. Larry and Steve from Boomerang Jets was at the Event, Very nice guys. Larry brought a Turnbinater and was kind enough to buddy box any one that wanted to fly a Jet.
https://www.dropbox.com/sh/4fwq3r7p0...7O__Jfe5a?dl=0
#75
My Feedback: (26)
I have several dozen flights on mine with an original 19lb thrust Rabbit, nice flying plane with no bad habbits. Only issues I've had have been with the poor quality of the cheap Chinese plywood that's used for the LG mounts. I had a rough landing a few weeks ago at Mississippi Afterburner that should have hurt my pride and nothing else, but the nose gear former came apart. Not a difficult fix, but something I shouldn't have to do. Two layers of 1/8" lite ply is no substitute for real 1/4" aircraft ply.
