Welcome to Club SAITO !
Old 08-06-2010, 10:54 AM
  #18176
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
Start cutting and show us what you have done?
Old 08-06-2010, 10:59 AM
  #18177
retransit
My Feedback: (18)
retransit's Avatar
"the back side of the motor mount surface"?
Illustrate, I'm a bit confused.
Bob
Old 08-06-2010, 11:01 AM
  #18178
w8ye
My Feedback: (16)
w8ye's Avatar
The plastic rear covers distort under the screw heads causing the carb mount to tilt out and the intake manifold to leak at the head
He wants to make an aluminum cover like a giant washer that covers all the screw holes to help support the plastic rear cover?
Old 08-06-2010, 11:10 AM
  #18179
retransit
My Feedback: (18)
retransit's Avatar
The light has turned on! Thanks.
Bob
Old 08-06-2010, 11:11 AM
  #18180
Jimmy Hoffa
Jimmy Hoffa's Avatar
Sorry I have not made an accurate description of what I'm talking about. I am looking to replace the washers on the surface opposite the motor. This would be beneficial on my profile plane where the flat washers slightly indent the wood.
Phillip
Old 08-06-2010, 11:40 AM
  #18181
w8ye
My Feedback: (16)
w8ye's Avatar
That has been done before and will work very well
Old 08-06-2010, 12:25 PM
  #18182
Jimmy Hoffa
ORIGINAL: w8ye
I was wondering if a company makes them? If not, I will do it myself and post some pictures here.
Phillip
Old 08-06-2010, 12:35 PM
  #18183
Jimmy Hoffa
Oops...deleted.
Phillip
Old 08-06-2010, 12:55 PM
  #18184
w8ye
My Feedback: (16)
w8ye's Avatar
no one makes them that I know of
Old 08-06-2010, 02:32 PM
  #18185
Sparky71
When will the Saito 90 twins be in? I ordered mine in June, first they said July and then August, well it is August and I do not have mine yet!
Old 08-06-2010, 02:35 PM
  #18186
Jimmy Hoffa
ORIGINAL: w8ye
Went to Home Depot and found a piece of 1/8" thick flat aluminum for $4.19. Will cut it with a hacksaw and clean up with a file and Dremel. Might even polish it!
Phillip
Old 08-07-2010, 03:27 PM
  #18187
jeffie8696
jeffie8696's Avatar
Flew my Saito .50 yesterday!!! First four stroke Ihave ever flown. I kinda like it. Better in a lot of ways than 2 strokes . Will 4 strokes replace all my 2 strokes, no probably not but I love variety so Iplan on using them a lot.
Now to install the Saito .40 on my Kadet Jr .
Old 08-07-2010, 03:35 PM
  #18188
spaceworm
I had a Kadet Jr. with an OS .25FP. 3 channel, no ailerons. I had an "expert" club flier fly it and he did not realize it was 3 channel. 'cause I hooked up the rudder to the aileron stick channel. Great fun.
Enjoy.
Regards,
Richard
Old 08-07-2010, 04:30 PM
  #18189
retransit
My Feedback: (18)
retransit's Avatar
See, he can fly with rudder!
Bob
Old 08-07-2010, 05:39 PM
  #18190
N1EDM
Hi Everyone, I have a two-part question.
First, was something new done to the Saito 125's? I'm thinking about asking Santa for one for Christmas (won't need it until then)... or am I th inking about the changes made for the Saito 82?
The plane that I want to put the 125 into is a Top Flite P-51D Gold Edition http://www3.towerhobbies.com/cgi-bin...EARCH=TOPA0110
Has anyone put the 125 into this plane? What's your opinion?
Was it too much engine?
Was the fit too tight?
Thanks for your opinions,
Bob
Old 08-07-2010, 05:50 PM
  #18191
JohnB96041
JohnB96041's Avatar
Send Santa that letter and you will never regret getting the Saito 125.
Old 08-07-2010, 06:39 PM
  #18192
N1EDM
Well, if it doesn't fit, it won't be of any use to me. I've already chosen the project. I need to know if anyone has tucked one under that TF P-51D cowl, and did they have any problems?
Thanks for the comment,
Bob
Old 08-07-2010, 07:47 PM
  #18193
retransit
My Feedback: (18)
retransit's Avatar
Bob,
Here are the measurements of the 1.25A:
Total length - 119mm or 4.685"
Height - 127mm or 5"
C/L crankshaft to top of head - 105mm or 4.133"
Overall width @ mounting boss - 60mm or 2.362"
All engine dimensions are here:
http://saito-engines.info/specifications.html
Bob
Old 08-07-2010, 08:14 PM
  #18194
spaceworm
ORIGINAL: Jimmy Hoffa
Phillip
I have made a "nut plate" out of copper clad PC board material to which I soldered the nuts for the engine holddown screws. I usually make it in a "U" shape so that the center of the "U" clears the bottom of the crankcase. If I want or need it captured to the engine mount or firewall or fuselage side, I just CA it or use a little screw. That way your nuts don't get loose and you lose them.
Regards,
Richard
Old 08-07-2010, 08:15 PM
  #18195
flashingred-RCU
Sign me up for the Saito Club. I own a 45, 56, 82, 100 and 2 115's. I like all but the 100 which is a vibrator. I have checked the balance of the prop and the tru turn spinner and back plate. I am wondering if the crank can be bent but I have not seen a wobble and I do not have a dial indicator to check the crank. Engine has a tendency to backfire when starting. Glad I use the double nut system.
Flashingred
Old 08-07-2010, 08:41 PM
  #18196
spaceworm
Vibration and backfiring are symptoms of needles being out, but I am having a senior moment and can't remember which one or which way. I am sure the experts will chime in. Good luck.
Regards,
Richard/Club Saito #635
Old 08-07-2010, 08:52 PM
  #18197
flashingred-RCU
Richard,
Thank you for your prompt reply. I will check the needle valves in the morning. My club members start flying at the break of day so I will be out to the field bright and early. I will keep you posted. I forgot to mention that I am running YS 20/20 fuel and an OS F plug.
Flashingred
Old 08-07-2010, 10:50 PM
  #18198
jeffie8696
jeffie8696's Avatar
Love the Kadet Jr, mine came with an OS25FP that was well worn, replaced it with a sweet Irvine .25 . That Irvine is just about broke in (after almost a gallon) and I think the Saito 40 would be really happy on it for break in. It only has 3 channels and it is wonderful to fly. Very relaxing.
Old 08-08-2010, 10:34 AM
  #18199
lauterbacher
Looking for some advice, I own a saito 125 and I really overheated it and now after cooling off I'm down on power. Were should I look for the problem? thanks
Old 08-08-2010, 10:37 AM
  #18200
mike early
mike early's Avatar
Hmm, when I first got mine, I over-heated it a few times to the point of dead sticks. I never lost any power, though.
