Welcome to Club SAITO !
Old 09-17-2008, 06:53 PM
  #12176
mk1spitfire
mk1spitfire's Avatar
Default RE: Welcome to Club SAITO !
How many inches back does my tank have to be (using saito 82) before I have to use a pump or rugulator. And do you just leave pressure nipple??
thanks
Old 09-17-2008, 07:27 PM
  #12177
Ken6PPC
ORIGINAL: cpsdd56
Hi all i'm new here and need some help with a problem I cant seem to find a good answer to anyware else. I have a great planes stuka that weighs a little over 8lbs.Its powered with an FA100 my first 4S and i'm thrilled with it. Now to my problem,I cant stand the look fo two blade prop i'm using now. I'm not looking for a speed demon just good scale speed. On the bench it spun a 14x8 Zinger pro at 9600 with 15% fuel. I would be willing to give up some rpm to throw a larger 3 blade prop. It seems to me that the fa100 has more power than this plane needs. Any advise will be greatly appreciated. Thanks
Perhaps no one knows for a fact what 3 blade prop will work with a FA100?
I have no personal experience with 3 blade props, but I imagine a 13 x 8 three blade prop would work for your application.
Old 09-17-2008, 07:41 PM
  #12178
mike early
mike early's Avatar
My online warbird buddy uses a 13x8 3-Blade prop on his Saito 100 and is happy.
I imagine the 14x7 3-Blade would be too much for the FA-100. I use that prop on my 125. The 15x7 3-Blade is too much for me.
Old 09-17-2008, 07:43 PM
  #12179
RC Specialties
cpsdd56,
I have a 1.00 on a H9 Corsair. I ran a Master Airscrew 14x7 three blade for awhile. It flew well. I went back to an APC 14x8 for better performance. The MA 14x7 will work for you. I still have mine.
Here is a pic with the MA 14x7. Actually, it did not load it up. I think the two would be comparable.
Jim
Old 09-17-2008, 08:09 PM
  #12180
beaver180
My Feedback: (10)
Ta da! There you go... a 13x8 or 14x7 Master Airscrew would appear to do you
http://www3.towerhobbies.com/cgi-bin...&I=LXAA39&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXAA40&P=SM
Old 09-17-2008, 08:39 PM
  #12181
mbrennan1
Can someone please give me the proper part #'s from Horizon for replacement bearings for a FA125? The code for that engine is AG?? and I can not find bearings for code AG.
Thanks in advance for any help.
Old 09-17-2008, 08:41 PM
  #12182
Michaelh
ORIGINAL: Ed Cregger
ORIGINAL: w8ye
The 17X8 and 18 X 6 are the correct props
Not to be argumentative (who me?), but my ST G2300 handles the 18x8 with ease and its a 1.40 two-stroke, as everyone knows.
I'll have to mount up my Saito 1.80 and run comparisons between the 18x8 and other prop sizes that have been mentioned here. Of course, it depends upon the airplane that one is flying too, as to whether a propeller is suitable or not.
Ed Cregger
I can get about 8800-9000 out of a 18x6w (thats on a good day) about 9200 on the 18x6 xoar and have ran them enough to realize thats about all the prop this engine wants.
BTW thats on 30% and geared towards 3D .
Old 09-17-2008, 08:55 PM
  #12183
Ken6PPC
ORIGINAL: mbrennan1
I know this isn't what you asked for, but this is where I would buy bearings. (Again!)
http://www.rc-bearings.com/catalog/p...roducts_id=125
Or these, if you wanted ceramics:
http://www.rc-bearings.com/catalog/p...roducts_id=124
OK, HERE are the links to bearings for your Saito 125 from Horizon, if you insist!
http://www.horizonhobby.com/Products...dID=SAI120S20A
http://www.horizonhobby.com/Products...odID=SAI120S22
The 125 uses the same bearings as the older 120 did. (code for the FA120 is L)
Old 09-17-2008, 10:15 PM
  #12184
beaver180
My Feedback: (10)
Not sure on the max distance away from the carb the tank can be... the guys have said the saito has great suck tho. I've gone way back to the CG with my tanks and am using the Cline regulators ( awesome they are ) and this way the height of the tank can also be higer or lower too.
I'd use the muffler pressure.
Old 09-17-2008, 10:29 PM
  #12185
NM2K
My Feedback: (14)
ORIGINAL: RPMcK
Right you are Ed about the prop needs to match the airplane. Be sure and follow through with your investigation and let the rest of us know what you learn. Thanks! Oh BTW aren't two strokers suppoose to produce more power the four strokers anyway? Oh yeah, but four strokers produce more torque, or so they say. Oh well, whatever. Your experment should be interesting.
Ron
If four-strokes (or any strokes) produce more torque, then they also produce more horsepower.
The limiting factor with pushrod actuated four-stroke engines is the reciprocating mass of the valve train and the usually low compression force springs that are being used to pull the valves back up and into their seats. Much over ten or eleven thousand rpm and most hobby four-strokes begin to have valve striking problems (by the piston). You might be able to add a couple of more thousand rpm with some four-strokes, but not with all of them. The Chinese four-strokes are known for having weak valve springs, thus permitting valve strikes at lower rpm.
An overhead cam model four-stroke, properly designed, could probably be revved to 20k rpm plus without a problem.
Honda of Japan sells a 250cc in line four cylinder motorcycle that redlines at 17k rpm, so we know it can be done. The ancient pushrod valve actuating system coupled with weak valve springs prevents our hobby four-strokes from revving up very high. Of course, most of us probably wouldn't want the high revving kind of an engine four our models anyway.
My point is that just being a four-stroke does not mean that an engine must remain a slow turning "torquey" engine. Revvers are quite easy to produce. I just doubt if anyone would want to buy them. <G>
And yes, with today's design philosophies, an equivalent displacement two-stroke will generally out perform a given size of four-stroke model engine.
Ed Cregger
Old 09-17-2008, 11:50 PM
  #12186
Michaelh
Does not mean they produce more HP just because they produce more toque.
Old 09-18-2008, 04:51 AM
  #12187
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: AJsToyz
I actually like them upside down or side mount for ease of hand starting. Otherwise they will run however you mount them.
Andy
You're still talking about ehgines??
Old 09-18-2008, 05:17 AM
  #12188
beaver180
My Feedback: (10)
LOL
Old 09-18-2008, 05:35 AM
  #12189
NM2K
My Feedback: (14)
ORIGINAL: Michaelh
If they produce more torque at the same rpm, there isn't any way that it cannot produce more horsepower. This applies to any engine type, not just four-strokes. I knew I shouldn't have left that qualifier (same rpm) out, but I forgot it before posting.
Ed Cregger
Old 09-18-2008, 05:37 AM
  #12190
NM2K
My Feedback: (14)
ORIGINAL: Old Fart
ORIGINAL: AJsToyz
Andy
That was a good one, OF. You jump started my heart before the coffee got there. <G>
Ed Cregger
Old 09-18-2008, 05:49 AM
  #12191
full-throttle
My Feedback: (35)
Hi Ed, do you still have the Saito 325 package for sale? If so, I will take it. Thanks, Mike
Old 09-18-2008, 06:53 AM
  #12192
Paul_BB
Thanks Andy,
So considering the engine is upside down, what's the correct vertical position of the bottom of the fuel tank relatively to the engines high end needle ?
Best,
Paul
Old 09-18-2008, 07:13 AM
  #12193
beaver180
My Feedback: (10)
The same as if the engine was upright... middle of the tank should be level with ( or slightly below ) the HS needle position.
CFN, Paul
Old 09-18-2008, 08:47 AM
  #12194
retransit
My Feedback: (18)
retransit's Avatar
ORIGINAL: Michaelh
Ed Cregger
Hey Ed, how about diesels? Low RPM, low horsepower, high torque.
Bob
Old 09-18-2008, 08:59 AM
  #12195
c550
My Feedback: (16)
Does anyone have any fuel consumption estimates for a Saito 82?
Dave
Old 09-18-2008, 09:36 AM
  #12196
sodbuster 1
sodbuster 1's Avatar
ORIGINAL: RC Specialties
Bob,
The thick walled header coupling is still available from Aerotrend. I prefer the cream colored coupling myself.
[link]http://www.aerotrend.com[/link]
Jim
Jim,
What is the right size to use with your muffler?
1.00
Old 09-18-2008, 10:52 AM
  #12197
Capt Lou
My .91S burns about 1-1.25 ounces per minute
Old 09-18-2008, 11:27 AM
  #12198
RPMcK
RPMcK's Avatar
Ed - I thought we were talking about prop applications for different engines. Of course you're discussion of engine theory and design was impressive and interesting. Thanks for sharing that information with us. I'm looking forward to seeing the results after you compare preformance between you're 140 two stroke and Saito 180. Be sure and put some numbers out here. I would really like to see the difference even though it is kinda' apples to oranges. But interesting never the less.
Have a great day,
Ron
Old 09-18-2008, 11:38 AM
  #12199
Paul_BB
Thanks Paul,
Paul
Old 09-18-2008, 11:53 AM
  #12200
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Saito typically burn about one OZ of fuel per cu. inch, the .82 would under one OZ per minute, Caps .91 figure is a little excessive unless he's under propped or over rich.
