Seagull Gee Bee Z
#602
RE: Seagull Gee Bee Z
ORIGINAL: mbgbe696
Mine is the same ,unless someone has another idea I quess I will put some clear chafe tape to keep from scratching or rubbing a grove.
#603
Finally got to maiden mine yesterday. I will post a video soon. Everything went fine, and the plane flies great. Had a motor mount bolt come loose and a couple of the crimps on my flying wires loosened up. Not sure why that happened but I will fix that soon.
#606
NY
Sweet! That plane holds a knife edge well, even at half throttle! Lands and taxi's well too! That Mintor really moves the Gee Bee right along. Nice job Ronnie, now you have given me more incentive to get back at my Gee Bee build. I came home from the Toledo show with a 1/3 scale Pitts complete with engine which kind of distracted me a bit hehe. BTW, what make & size prop did you run on this engine? Any idea what max RPM your seeing? Pete
#607
Yea, the knife edge was almost too easy. It needs very little rudder to maintain altitude. The plane is very sensitive to yaw, which is to be expected being as short coupled as it is. There was a little cross wind and I kept trimming the rudder back and forth until I figured it was just the wind.
Now I have to fix the flying wires and add my graphics to it.
#609
ORIGINAL: lomcevac540T
Not a great video, but it is proof of a flight!
[link=http://www.youtube.com/watch?v=oIMaR_zdcd8]first flight[/link]
May i know the weight of the plane?
ORIGINAL: maneba
Good sound and safe landing.
I left the plane a little nose heavy on purpose. I know that this helps with the bouncing that many people are having troubles with. I am using the stock tires. After that first landing I know that I need to keep a little more speed on the plane at touchdown to keep the tail from dropping and making the plane bounce. I think the trick is going to be letting off of the elevator as soon as the wheels touch so that it lets the tail come up until the speed is blead off.
#612
I haven't weighed the plane yet. I will weigh it this week and let you know.
Now my works are suspended. I'm waiting the 24 oz tank and the Williams Brothers dummy engine.
#614
NY
Yeah since we are adding extra support wires to our oleo struts our planes will come in a bit heavier. I am also adding a TME smoke system which includes an extra battery pack for pump motor, and additional 16 oz tank for the smoke oil! The wing loading is light on this plane to begin with, so I think it should fly fine. All the other planes I read about on this thread were around the 11 to 12lb weight when finished.
#617
NY
Hey Buddy, yeah I'm still following this thread. Just been too busy with work to finish my GeeBee. Hope to really get back to it this week end. Would be nice to finish it now that our good flying weather is here up north! How is you plane holding up? Any issues pop up? Pete
